Multi-Table Extraction stencil
The Multi-Table Extraction stencil is used to automatically extract information from documents using a machine AI learning model. The advanced functionality allows you to extract line items from multiple tables on a single document. When this stencil is used, the document does not have to go through OCR or be trained.
After going through the Multi-Table Extraction stencil, each data field will be highlighted on the document as follows:
  • Green = 80% or higher confidence
  • Yellow = 50% - 80% confidence
  • Red = under 50% confidence
Note: Each document that is processed through this workflow stencil will decrement your page count license by the number of pages displayed.
All extracted data fields will be available on the Journal tab in Document Properties. See View document properties for more information.
Available connections
There are two outgoing connections from a Multi-Table Extraction stencil: green if the extraction was successful and red if the extraction failed.
Configuration
  1. To access stencil properties, double-click a Multi-Table Extraction stencil. Or, right-click an Multi-Table Extraction stencil and select Properties.
  2. In the Display Name box, enter a name for the stencil. The display name will be the name of the folder representing the workflow step in the Document Panel.
  3. Configure the stencil using the following tabs:
  4. Click Save.
