Known Issues
This page lists important information about issues that apply to OL Connect 2026.1.2.
OL Connect Chromium 2026.1 Known issues
The following features are waiting to be implemented in OL Connect Chromium.
Missing email attachments are treated as warnings instead of errors. This will be fixed in the 2026.2 release.
Color management (i.e. support for color profiles) is not supported for images.
CMYK output is supported for custom colors, but images in CMYK format (with or without a color profile) will be changed to RGB format.
When printing to PDF, the non-RGB custom color of an element is lost when its parent is transparent, such as CMYK colored text inside a transparent paragraph. Transparency for custom colors is not recommended for non-PDF output due to compatibility and performance issues.
The Facing pages feature, which alternates the side margins in Print output, is not supported in this version of OL Connect. If you require Facing Pages, please open this template or document in a previous Mozilla Gecko-based version of OL Connect.
There are some minor usability issues. For example: formatting multiple boxes at the same time is not yet possible.
There is currently a known limitation in the line thickness values that can be applied in the Chromium version. Lines are always converted to whole-pixel values. This causes any line thickness below 1 pixel to be converted to 0.75 points (the equivalent of 1 pixel), and any line thickness between pixel values will be rounded up or down to the nearest whole-pixel equivalent.
There is currently a known limitation with string fields conversion to date fields.
The following approaches work correctly:-
Passing a string to
formatter.date(or another date function) in a script works correctly. -
Using a string field with
{{date field}}(or another date function) works correctly.
The following does not work, however:
Using
data-formatin a dynamic table using a date format and a string field
Templates using the CSS style
position: fixedmay no longer produce correct output.To ensure correct rendering, use
position: absoluteinstead. Existing templates that rely onposition: fixedshould be updated accordingly.
PDF image pass-through issues
Using PDF files as images has limitations in the Chromium version of Connect due to the lack of the support in the browser engine.
Using a PDF file for an image fails when using the grayscale conversion feature. Workarounds and fixes are being tested.
Using a PDF as an image source (via
<img>or CSS backgrounds) in a template can fail silently and produce visual artifacts when the rendered or visible portion is very small, heavily clipped, repeated, or combined with long filenames. As a workaround, use a rasterized version (e.g., PNG) for small or partially displayed PDF images.
+PReS Enhance issues with Chromium version
The +PReS Enhance Read Connect plugin is not yet fully compatible with a job set generated by OL Connect Chromium 2026.1.
This plugin is typically used by a custom +PReS Enhance Workflow Configuration.
This issue will be fixed in a later release.
Scripting issue with non-existent properties
In OL Connect Chromium 2026.1, if a script tries to use typeof to determine whether a property is defined and that property does not actually exist, then a ReferenceError is triggered. The rest of the script is not executed.
A workaround for typeof being used to determine if a record is the first record of a job (a common usage) is to instead check for record.index == 1.
Script API setting changes in 2025.1
In OL Connect 2025.1 stricter checking was introduced for the Uniform Resource Identifier (URI) passed into the loadhtml, loadjson and loadtext scripting functions.
Special characters such as spaces in a path used to work but now need to be properly URI encoded.
Example: // Worked in 2024.2 but not in 2025.1
var result = loadhtml("file:///C:/PPWorkDir/Hello World/Data/Example.html");
// 2025.1 onwards
var result = loadhtml("file:///C:/PPWorkDir/Hello%20World/Data/Example.html");
This applies to more than just the space character. Refer to RFC 2396 for the rules on URI encoding.
Email setting change in 2025.1
In OL Connect 2025.1, we fixed an issue where the “Do not inline styles” option would still inline CSS style rules on elements. This might affect existing jobs, particularly if you were inadvertently using the “Do not inline styles“ option but wanted the 'Apply CSS properties to elements’ behaviour.
Dynamic email attachments issue (updating from 2024.2.1)
Issues with Dynamic email attachments, which were added using custom scripts or via the Dynamic Attachment wizard.
The issue was that dynamic email attachments would accumulate across multiple messages. Additionally, when testing in the Designer application, this could cause attachments to be unintentionally added to the template.
As of 2024.2.2 we now ensure dynamic email attachments are handled correctly, with each email containing only the intended attachments and templates being saved properly.
If you are using dynamic attachments in your templates, we recommend testing them after updating to confirm that everything is functioning as expected.
Adding entries to manually added detail tables
The addRow() functionality did not work for detail tables that were manually added to the Data Model, prior to OL Connect version 2023.2. The fix for this issue allowed the use of addRow() for detail tables that are manually added to the data model or which have no extracted rows. As a result, any detail table without extracted data is now recognized as an existing but empty table, with a length of 0.
Remote translation files issue
Changes in a remote PO file (.rpo) are not shown in Preview mode or when double-clicking the .rpo file.
This will be addressed in a future release.
Performance not scaling as expected
When you have a machine with a lot of CPU cores and you configure Connect to run many Merge Engines (8+) simultaneously, the performance can be less than expected.
It has been reported that the CPU is not fully utilized and the performance per Merge Engines actually goes down, the more Merge Engines you add.
Unicode Variation Selectors issue
The Designer and Merge Engine can crash when a document or input data contains a Unicode Variation Selector. A variation selector is a special Unicode character in the range of U+FE00 - U+FE0F that indicates which variant of the previous character should be used.
The issue has so far only occurred on Windows 11 systems and will be fixed in a later release.
ODBC drivers do not all work with OL Connect
ODBC drivers do not all work with Java applications.
Since OL Connect is a Java application, it is strongly recommended you use JDBC instead.
Incorrect colors in print preview
Colors are not displayed correctly in previews generated by the Advanced Print Wizard.
Account permission issues
If you install and run OL Connect Designer
It is recommended that you install and use OL Connect Designer
Issues converting some images from PCL to PDF
Problems have been reported with the conversion of some images, from PCL files to PDF output.
In some, the image is replaced with a grey box. In others, the images convert, but with a vertical line added to the edge of the image.
This is due to an issue with a third party library which will be addressed in a future release.
Incorrect warning when sending email from Designer
When sending email from the Designer with a license that allows this, an incorrect warning is displayed stating that sending email is not covered by the license. The warning does not prevent the emails from being sent.
Master Page not affected by style rules for <body>
In the output, content in Master Pages is affected by style rules targeting <html>, but not by style rules targeting the <body> element. This is because in the output, they are placed outside the <body> of the section to which they are applied. When editing a Master Page, style rules targeting the <body> element will work, because the Master Page is not currently applied to a section, but they will have no effect in the output.
Dynamic tables causing issues
In some specific circumstances the dynamic tables feature does not behave correctly. The following scenarios should be avoided to prevent subsequent issues with the template:
Using
page-break-before:alwaysorbreak-before: always;on the top TR of a TBODY causes a problem and results in a pagination error -
It is possible to specify conflicting attributes on a TR element:
page-break-before:alwaysorpage-break-after:alwayscombined with data-repeat -
page-break-after:alwayscombined withpage-break-before:avoidon the next sibling TR (or similar combinations)
These issues will be addressed in a later OL Connect release.
DataMapper: Automatic Date/Time does not work with certain negative UTC time zone offsets
The new "Automatic" date parsing option in the DataMapper cannot parse dates with negative UTC time zone offsets of non-zero minutes.
For example: 2021-03-01T10:00-03:00 will work, but 2021-03-01T10:00-03:30 will not.
Positive time zones with non-zero minutes (such as +10:30) are unaffected.
The negative time zone offsets affected are: UTC -02:30; -03:30; -04:30 and -09:30
This issue will be fixed in a later release. In the meantime, the workaround is to use “Custom” or “ISO8601” date parsing options in DataMapper.
Print Wizard Preview showing some Landscape mode jobs in Portrait mode
Print jobs featuring associated Connect Output Presets which have Imposition options set to Landscape will not Preview in Landscape, but rather in Portrait mode. The printout is unaffected, however.
Issue after erroneous or incomplete update or re-installation
If one or more products (the OL Connect Designer, Connect Server, Software Activation, Print Manager, or Server Configuration Tool) or engines exit within a second of starting, this may be caused by a recent erroneous or incomplete uninstall before a reinstall or upgrade to a newer version of OL Connect.
This may be solved by deleting the %UserProfile%\Connect\.eclipse directory.
Backend database might require periodic maintenance
Databases maintain a variety of statistics in order to optimize performance. When high levels of inserts and/or deletions occur, the statistical data keeping can struggle to keep up. Over a period of prolonged and intensive processing this can result in a degradation in performance, with the whole database slowing down as it struggles to clean itself up.
In Connect terms the effect can be felt as the Data Mapper and/or Job Creation progressively slowing down.
To cure this issue, it is recommended that you periodically run manual maintenance on the backend database.
If using MySQL, the following script should be run in a query window:
set @a=null,@c=null,@b=concat("show tables where",
ifnull(concat(" `Tables_in_",database(),"` like '",@c,"' and"),''),
" (@a:=concat_ws(',',@a,`Tables_in_",database(),"`))");
Prepare `bd` from @b;
EXECUTE `bd`;
DEALLOCATE PREPARE `bd`;
set @a:=concat('optimize table ',@a);
PREPARE `sql` FROM @a;
EXECUTE `sql`;
DEALLOCATE PREPARE `sql`;
set @a=null,@b=null,@c=null;
If using Microsoft SQL Server run the following command in a query window:
sp_updatestats
Windows 10 Search service impacting Connect
The Windows 10 Search service runs as a background task, indexing files and folders. It has been noted that this background task is sometimes preventing files being added to the Connect temporary files folder when large amounts of files are being output and copied.
If this is an issue for you, we suggest disabling Search Indexing on the C:\Users\<username>\Connect folder.
Known Font issues
The following font(s) are known to have issues in OL Connect 2026.1:
- Benton Sans CFF font
Windows Server 2016 issue
As of OL Connect 2018.1 Connect is officially supported under Windows Server 2016.
Please note, however, that the Update Client application might be blocked by the enhanced security settings in Windows Server 2016.
To fix this, add http://updates.ca.objectiflune.com to the list of trusted web sites on that machine, or lower the internet access rules.
Limit of 100MB of image files within a single job
There is a limit of 100MBs for image files included within a single job. This allows most jobs to run faster. However, if a job requires more than 100MBs of image files, then the OL Connect image cache size can be increased. Please contact Support for instructions on how to modify the image memory cache value, if needed.
Memory usage in clustered environments
If Database Petitioning is not selected, then OL Connect can fill the database faster than the Clean-up service can clear it (the ratio is approximately 3:1), in high speed clustered environments. Therefore if the system needs to run for some time under a considerable load, a larger database should be used to prevent production from being interrupted. Or set the clean-up service to use Database Partitioning.
We also recommend only the Master Server performing the database clean-up, or the local Server Extension if the database is not installed with the Master, to maximize performance. For all Designers, Server and Server Extensions except one, set the clean-up of the database entities to run every 100 months and disable the clean-up for any Designer which also has a Server or Server Extension on that machine.
Note that if the Designer is a stand-alone then it is not connected to the central database for clean-up purposes.
The Database Petitioning option can be found in the Clean-up Service preferences.
Issues with Microsoft Edge browser
The Microsoft Edge browser fails to display web pages when the Workflow's CORS option (in the HTTP Server Input 2 section) is set to "*". This issue will be resolved in a future release.Installation paths with multi-byte characters
Switching languages
Changing the language using the Window > Preferences > Language Setting menu option does not currently change all of the strings in the application to the selected language. This is a known issue and will be fixed in a later release.
- Go to the .ini files for the Designer and Server Config:
C:\Program Files\Objectif Lune\OL Connect\Connect Designer\Designer.iniC:\Program Files\Objectif Lune\OL Connect\Connect Server Configuration\ServerConfig.ini
- Change the language parameter to the required one under Duser.language=en | es | de | fr | it | ja | ko | pt | tw | zh
GoDaddy certificates
MySQL Compatibility
The minimum supported MySQL version is MySQL 5.6.
PostScript print presets
The print presets for PostScript were changed from Version 1.1 onwards meaning that some presets created in Version 1.0 or 1.0.1 may no longer work.
Any PostScript print preset from Version 1.0 that contains the following will not work in Version 2026.1: *.all[0].*
Any preset containing this code will need to be recreated in Version 2026.1.
Available Printer Models
Note that the descriptions of some of the printers were updated in version 1.2 meaning that if you had version 1.n installed, you may find that the same printer style appears twice in the list, but with slightly different descriptions.
For example the following printer types are actually identical:
- Generic PS LEVEL2 (DSC compliant)
- Generic PS LEVEL2 (DSC)
External resources in Connect
There are certain limitations on how external resources can be used in Connect. For example if you want to link a file (e.g., CSS, image, JavaScript etc.) from a location on the network but you do not want to have a copy of the file saved with the template you need to do the following:
- The resource must be located where it can be accessed by all Servers/Clients run as users. Failure to do this will cause the image to appear as a Red X in the output for all documents which were merged by engines which could not access the file. The job will terminate normally and the error will be logged.
- The file must be referenced via a UNC path e.g.,
file://///w2k8r2envan/z%20images/Picture/Supported/JPG/AB004763.jpg
- UNC paths are required because the services will be unable to access mapped network drives (Windows security feature).
- The engine processing the job will look on the local file system for the direct file path leading to the “resource not found” issue mentioned above.
Caution: The Designer itself and Proof Print do not use processes that run as services and they may find local files with non-UNC paths which can lead to the false impression that the resources are correct.
Color Model in Style Sheets
The color model of colors defined in a style sheet can sometimes change after editing the style sheet. This is a known issue and will be addressed in a subsequent release.
Image preview in Designer
- Images will be shown as 0 size boxes (no red 'X' is displayed).
- Live preview does not progress, and when re-activated reports "browsers is busy".
Merge/Weaver engines when printing
The print operation in the Designer will automatically detect whether the Merge\Weaver engines are available and display a message for the user to retry or cancel if not. Once the Merge/Weaver engine becomes available and the user presses retry the print operation will proceed as normal. This message can also occur in the following circumstances:
- If the server is offline and you are not using Proof Print.
- On some occasions before the Print Wizard opens.
REST Calls for Remote Services
The Server will accept REST calls for all remote services and will make commands wait indefinitely until the required engines become available. The Server will log when it is waiting for an engine and when it becomes available. Note that there is no way to cancel any commands other than stopping the Server.Print Content and Email Content in OL Connect Workflow
In OL Connect Workflow’s Print Content and Email Content tasks, the option to Update Records from Metadata will only work for fields whose data type is set to String in the data model. Fields of other types will not be updated in the database and no error will be raised. This will be fixed in a later release.
Print Limitations when the Output Server is located on a different machine
The following limitation may occur when using the Print options from a Designer located on a different machine to the Output Server:
- The file path for the prompt and directory output modes is evaluated on both the client AND server side. When printing to a network share it must be available to BOTH the Designer and Server for the job to terminate successfully.
- The Windows printer must be installed on both the Server and Designer machines.
- When printing via the Server from a remote Designer, the output file remains on the Server machine. This is remedied by selecting “Output Local” in the Output Creation configuration.
VIPP Output
Magic Number changes when installing Docker
Installing Docker on a system where Connect has already been installed may impact Connect's licensing mechanism and require reactivation.
Note: Installing Connect after Docker has already been installed will not cause issues.
