OL Connect Release Notes 2024.2
License Update Required for Upgrade to OL Connect 2024.x
From OL Connect 2019.1 onwards, only customers with a current OL Care subscription will be able to update OL Connect.
Every OL Connect license now contains an end date that represents the last day of OL Care coverage for each customer. Upgrades and updates of OL Connect will be freely available up until that end date, but will not be available thereafter, unless the OL Care period is extended.
This licensing model requires anyone upgrading from OL Connect versions earlier than 2019.1 to first update their OL Connect License. A dialog box appears as part of the OL Connect upgrade process requesting that you do this.
It is recommended that you first update the OL Update Manager, as newer versions of the Update Manager can update your OL License to the required version.
For further details on how to upgrade the OL Update Manager to the latest version and update your OL Connect License see the Update Manager 1.10 - Upgrade Guide.
If issues arise, or if you need to renew your OL Care subscription, please contact your local Customer Care group.
Backup before Upgrading
Overview
This document provides an overview of the new features and enhancements in OL Connect 2026.1 and Workflow 2026.1, as well as some important installation information.
Installing OL Connect 2026.1 and Workflow 2026.1
    OL Connect: Installation and activation.
OL Connect and Workflow installers require Administrator rights
OL Connect templates used in Workflow
For improved performance we recommend re-saving any OL Connect templates used in Workflow to the current version of OL Connect templates.
It is possible to install OL Connect on a machine with a minimum of 2 GB of RAM. The OL Connect Designer will automatically detect whether it has been installed on a machine with less than 4 GB of RAM and default to only using one internal Weaver and one internal merge engine on that system. The Server will also run using internal engines.
OL Connect 2024.2.3 Improvements
Data handling regression issue
A data handling regression issue was discovered with CSV/Excel data when running existing Templates. This issue was introduced by new auto-detection functionality, added in the 2024.2 release.
A option to "Automatically detect data types" has now been added to the data mapping configuration dialogs, to allow switching between the new behavior (checkbox selected) or the old. (94522)
Installation regression issue
Some users upgrading from earlier versions erroneously had their Server Engine set to "Restrict to localhost". This resulted in stricter than intended security settings for upgrading customers. This has now been fixed, for most scenarios. (94650)
Note: Users who upgraded to OL Connect 2024.2.1 from a version prior to 2024.2, and then subsequently upgraded to 2024.2.2 may have the "Restrict to localhost" checkbox erroneously selected. Users will need to unselect the checkbox to restore full functionality.
Web section regression issue
Fixed a problem that could trigger errors in the Designer for web sections that include custom JavaScript resources. (94706)
Section background causing blank pages
Fixed an issue with sheet configuration that could produce additional unneeded blank pages in certain cases when a section background was used. (94745)
OL Connect 2024.2.2 Improvements
Some regression issues were discovered specific to 2024.2.1. These issues have been addressed in 2024.2.2. They were:
  • Issues with dynamic email attachments in templates. Both those that were added using custom scripts or via the Dynamic Attachment wizard. This issue did not impact scenarios involving the Print context attached as a PDF or static attachments, and it did not affect earlier versions of the software.
    The issue was that dynamic email attachments would accumulate across multiple messages. Additionally, when testing in the Designer application, this could cause attachments to be unintentionally added to the template. We now ensure dynamic email attachments are handled correctly, with each email containing only the intended attachments and templates being saved properly.
    If you are using dynamic attachments in your templates, we recommend testing them after updating to confirm that everything is functioning as expected. (94522)
  • Remote translations files could not be added to templates. In templates that already had remote translation files added, you could no longer update any properties nor view the content of the remote file in read only mode. (94536)
OL Connect 2024.2.1 Improvements
During the OL Connect 2024.2.0 partner preview a regression issue was discovered with the Preferences dialogs, Print Manager and Server configuration tool not displaying all options. This was fixed for the 2024.2.1 release. (94142)
OL Connect 2024.2 Improvements
Architectural Software Updates
  • Java: Updated the Java platform which OL Connect runs on to Adoptium Temurin version. 21.0.3. (92074)
  • MariaDB: Updated the database that is packaged with OL Connect to 11.3.2.
Security improvements
  • Third party libraries updated to recent versions. (92741)
  • The Quartz Library has been removed and this may affect your Clean-up Schedule due to the change in CRON specification. (92748)
  • Cross-Origin Resource Sharing (CORS) is now disabled by default. Use of CORS now requires a whitelist of allowed origins to be specified. (92863)
  • JavaScript Libraries used by OL Connect have been updated to current versions. (92983)
OL Connect REST API improvements
  • The JSON Operation List output from the Get Operations method of each OL Connect Workflow-based service will now include (when available) the Managed File Name and ID of any configuration file or files included in a Workflow operation.
    Examples include Data Mapping configurations, Templates, Job Presets and Output Presets. (89588)
  • A new Get Runtime Parameters for Data Mapping Configuration endpoint has been added to the Filestore REST Service. This endpoint will return a list of the runtime parameters in a Data Mapping configuration, including their name, type and debug value in either XML or JSON format. (92718)
  • A new Get Runtime Parameters for Job Preset endpoint has been added to the Filestore REST Service. This endpoint will return a list of the runtime parameters in a Job Preset, including their name, type and default value in either XML or JSON format. (93089)
  • Several Connect REST API endpoints have been updated to now support on optional job output folder parameter (jobOutputFolder) which can be specified to override the output directory of an Output Creation Preset. (93211)
    The endpoints are:
    • Output Creation Service:
      • Process Output Creation (By Job Set) (JSON)
      • Process Output Creation (By Job) (JSON)
    • All-In-One Service:
      • Process All-In-One (JSON)
      • Process All-In-One (Adhoc Data)
  • The JSON Job Set Statistics output of the Get Job Set Statistics method of the Statistics service can now return statistics based on one of three levels. (93225)
    The levels are:
    • document only - returns only a list of documents contained in the job set. (Default)
    • document set only - returns only a list of document sets contained in the job set.
    • document set all - returns a list of document sets (including all of the documents) contained in the job set.
  • A new Get Runtime Parameters for Template endpoint has been added to the Filestore REST Service. This endpoint will return a list of the runtime parameters in a template, including their name, type and default value in either XML or JSON format. (93574)
  • OL Connect REST API restricted to localhost access by default. (93625)
    This can be changed by a new setting in the Server Configuration dialog.
  • Cookies used with Rest API calls now have the HttpOnly flag set. (92866)
OL Connect backend improvements
  • Fixed issue with database preferences prompting a database restart warning when settings reverted back to original settings. (92615)
  • Resources being used in Content, Job and Output creation are now clearly identified in the engine logs. (92702)
Update AFP input
The AFP-to-PDF input tool (which converts AFP input to PDF) was rewritten.
This addresses the following issues:
  • Input fidelity has been improved for AFP input files used for data mapping. CMYK images in an AFP input file now keep their CMYK colorspace. In previous versions of OL Connect, such images were converted to the RGB colorspace which could lead to inadvertent color changes for those images. (88722)
  • An issue has been fixed that occurred when processing AFP input files that could cause pages in some AFP files to become blank. (91945)
  • There’s a change in how a setting for AFP-to-PDF conversion needs to be customized/modified.
    This only affects customers that have modified a setting in the AFP-to-PDF config.ini file that existed in the installation folder of OL Connect 2024.1.2 and earlier. (93357)
Note: There might be very small differences in the output generated from the current version, when compared to the output from the previous version.
OL Connect 2024.2 Designer Improvements
Cloning Section improvements
OL Connect 2024.2 introduces real-time preview of section clones and their personalization during the design phase, eliminating the need to generate output for each iteration. (92017)
The enhances include a new Clone Section script wizard for creating scripts for sections that are based on detail tables.
This new wizard simplifies the creation of print section clones from detail records, without the need for scripting. It also allows for specifying unique background images for each clone by providing the image path in a detail record field.
It automatically stores detail record table and index information with each clone, replacing the previous manual process. Enhanced functions in the scripting API and new Handlebars helpers facilitate easy retrieval of this data and simplify personalization.
The Wizard also automatically disables the original section and allows you to assign a unique background image specified in the data for each instance. The latter is useful in scenarios such as textbooks or other document types where file paths (including URLs) are provided in the detail records.
The Resources panel displays cloned sections in the designer preview pane, so you don't need to publish in order to check your work.
Address Block improvements
  • The Insert Address Block dialog now remembers the last applied address format template, instead of going back to the locale default. (92527)
  • Address Block has now been made read-only in Preview mode. (93172)
  • Added support for the United States Postal Service Ancillary Service Endorsement (ASE) and IMb barcodes. (93362)
  • If the Address Blocks working folder doesn’t exist yet, it gets created. (93513)
Handlebars improvements
  • Improved handling for reserved characters contained within square brackets or quotes. (92803)
  • Fixed an issue where Handlebars expressions in table captions would not be replaced. (92805)
  • Introduced a “counter” helper for Handlebars. (93115)
  • Simplified passing a detail record as a custom context to a Handlebars partial. (93337)
  • Fixed an issue that could cause Handlebars expressions in elements with data-translate to become hard-coded in Master Page content. (93382)
General Designer improvements
  • The Designer Messages View was not catching log messages prior to it displaying. This has been fixed. (64681)
  • Introduced Remote Control Scripts to access control scripts not found within the Template. (87605)
  • Improved the Auto save feature. It now postpones saving if the Designer is busy. (90672)
  • Added option to quickly Duplicate resources. (90695)
  • We now support inserting barcodes in snippets. Note, though, that barcodes cannot be absolute positioned in snippets. (90772)
  • Added a new menu item for adding sample data. (90868)
  • Introduced a View Menu to the Data Model view. (91073)
  • Improved matching character highlighting (for CSS, HTML and JavaScript). (91177)
  • Preference pages can now be filtered on keywords found in the contents, not just in the titles. (91311)
  • Added an Image section to the Attributes view. (91561)
  • Fixed an issue where a post pagination script would be unable to modify master content after merge.section.paginate() was called. (92075)
  • Improved error handling for loading remote content, and Handlebars partials in particular. (92119)
  • Fixed a problem with the Send COTG Test when used in combination with JSON sample data. (92245)
  • Added Preference to hide any ExtraData field(s) from the Data Model view. (92337)
    When disabled no ExtraData entries are shown in the Data Model view and the show/hide ExtraData icon on the toolbar is hidden.
  • Added "drag and drop" and "double click on Data Model fields" support to the URL field for hyperlinks in the Attributes panel. (92428)
  • Added support for sentence case as an option for the string formatter object and as string formatter in Handlebars expressions. (92530)
  • Added ability to access Section metadata entries in Print Context. These properties can then be accessed in standard User Scripts or through the @meta helper in Handlebars. (92574/93383)
  • Added support for a built-in "lookup" helper for Handlebars. (92576)
  • Fixed an issue whereby on some machines the UI language could not be changed. (92636)
  • The Designer Messages View was not catching log messages prior to becoming visible. This has been fixed. (92687)
  • Prevented an error dialog from popping up after clicking Cancel while opening an editor. (92783)
  • Changed the default scale option for QR and DataMatrix barcodes to Proportional. (92868)
  • Prevented an unnecessary error about core.css being logged when switching to Live mode. (92940)
  • Labels in the Resources panel now include a count that represents the number of child entries (excluding folders). (93020)
  • Disabled Section Background settings are no longer used when a Section Background is enabled in scripting. (93197)
  • Fixed a problem in the Show View menu where it would show less items for certain languages. (93198)
  • Fixed a pagination issue that could cause cosmetic issues in the Designer. (93215)
  • Improved the behavior of forced page breaks in pagination, when job is Previewed. In certain rare cases this may lead to small differences in output, particularly when it comes to the margins of elements at the top and bottom of each page. (93256)
  • Added ability to launch the Section Clone wizard by right-clicking a section in the Resources panel. (93511)
  • Fixed an issue that could cause edit helpers (for dragging and resizing) to be persisted in Templates and in some cases even appear in output. This only occurred for sections that use Handlebars and/or JavaScript resources. (93533)
OL Connect 2024.2 DataMapper Improvements
  • When trying to create a DataMapper with PDF in Designer, the credential pop up is no longer shown. (89138)
  • Fixed extension problem in “Load JavaScript” dialog of DataMapper. (89154)
  • Added auto-detection of field data Type (integers, booleans, currencies, floats and dates) for the CSV/XLS data wizard. (91511)
  • Improved validation for DataMapper config with preprocessor. (91744)
  • Preprocessor and Postprocessor submenus had their label changed to “Actions” for greater clarity. (92085)
  • DataMapper Context Sensitive Help improved. (92114)
  • Fixed problem with XLS data in Designer when “Move back record” action is called. (92357)
  • Removed an incorrect reference for the sourceRecord object in the DataMapper boundaries scripting engine. (92432)
  • The Lines to skip parameter in CSV and Excel data can now have a value up to 10,000. (92442)
  • A progress indicator is now logged in the DataMapper engine logs as document boundaries are being evaluated. (92536)
  • Trim option “None” has been fixed in data model view of DataMapper. (92677)
  • Updated the JDBC-ODBC bridge, replacing the older, deprecated JDBC-ODBC bridge. The older version can still be used if required for backwards compatibility. (93295)
  • A new jdbc:olodbc bridge is available in the DataMapper scripting engine for data selection. (93297)
OL Connect 2024.2 Output Improvements
Print Wizard\Preset enhancements
  • Fixed an issue where attempts to import a printer definition could sometimes display a “Printer not available” error even though it has been successfully imported. (90670)
  • Fixed an issue that would occasionally cause the last used preset file(s) in the Print Dialog to load as “<Last Used Settings>” when no change to the preset file had been made. (92645)
  • Added support for localized font names for Output Preset additional text. (92710)
  • Added support to the PPD import feature in the output and print wizards for WindowsANSI language encoding. (93819)
Print Output Improvements
  • Improved memory footprint when producing AFP output. (93272)
Workflow 2024.2 Improvements
  • Third party libraries (including OpenSSL libraries) updated to more recent versions. (91547/91938)
  • Workflow updated to use latest Microsoft Visual Studio in compilation, necessitating installation of Microsoft VC 2022 redistributables. (90592)
  • The older Microsoft 2010 and 2012 Runtimes are no longer necessary and will no longer be installed on a user's system, unless the Laserfiche tools are installed, which is not the case by default. (92186)
  • The WinSCP library used in the SFTP/FTPS plugin was updated to 6.3.3. (92869)
  • Several connector plugins have their network client upgraded to the latest available version.
    Server certificate validation of custom plugins now matches the behavior of normal Workflow plugins based on the "Validate server certificate when establishing an outgoing secure connection” option. (92353)
General Workflow Improvements
  • Printer names with non-ASCII characters would cause the Workflow setup to error on un-installation. This has been resolved. (88237)
  • PDF Merging has been improved to take advantage of the optimization available in recent Adobe libraries. (89404)
  • New Workflow preference added to configure the includes for Enhanced JavaScripts. (89492)
  • A problem was fixed where Connect plugins running in self-replicated processes might fail with “could not bind socket” or “socket error #10057” error messages. (90789)
  • Secure Email Input task now has the ReplyTo field in its output displaying the Reply-To addresses used in the email. (91255)
  • A problem was fixed where storing data larger than 1 MB in Workflow metadata would cause memory corruption and crashes. The problem was resolved by rejecting values larger than 1 MB. This might cause processes that appeared to work fine to now error out explicitly. (91959)
  • A problem was fixed where the content of fields containing extended Unicode characters was lost when retrieving data records with the Execute Data Mapping or Retrieve Items tasks. (92143)
  • Enhanced functionality to correctly download and save embedded email files. (92363)
  • A problem was fixed where Workflow was reporting an incorrect magic number when running on a supported cloud environment if a license file was installed. (92423)
  • A problem was fixed whereby having a special XML character, such as an ampersand character, in the file mask of the Folder Listing plugin would result in an invalid XML file due to the special character not being properly escaped. (92583)
  • Workflow now saves the body of Microsoft 365 emails in UTF-8 format. (92631)
  • The content of the LPD control file is now available in job info #7. (92633)
  • The Translator plugin Source and Target encodings now have UTF-7, UTF-8, UTF-16 LE and UTF-16 BE encodings displayed at the top of the encoding list. (92655)
  • LPD Input plugin job info values for control file variables are now being properly initialized when executing the plugin. (92795)
  • The Lookup in Microsoft Excel Documents plugin has been moved to the Legacy category. It is recommended only using with old configurations. (92834)
  • A problem was fixed where uploading a binary file, such as a PDF, to the NodeJS Server Input would result in a corrupt data file. (92886)
  • The Microsoft .NET 4.6.2 Framework redistributables are no longer included in the OL Connect Workflow installer, as they are installed by default on supported Windows OS. (93074)
  • A problem was fixed whereby characters from another language would be converted to question marks when changing an existing Workflow metadata field value. (93666)
Known Issues
As of OL Connect 2018.1 the Known Issues have moved from the Release Notes to the OL Connect Online Help.
