User accounts and security
Windows user account
Connect requires local Windows Administrator rights when installing the software and activating the software license. This is to allow read/write access to protected Windows folders and registry entries.
Note: Installing as the Local System account is not supported.
Once installed Connect requires only standard Windows user credentials to run.
The following links contain the details as to when and where Windows Administrator rights are required:
- Connect Installation: Installation Wizard
- Activating Connect: Activating OL Connect
Permissions for OL Connect Designer
OL Connect Designer does not require any special permissions to run besides that of a regular program.
It does not require administrative rights and only needs permission to read/write in any folder where templates are located.
If generating Print output, OL Connect Designer requires permission on the printer or printer queue to send files.
