File Store - Delete File
The File Store - Delete File task deletes a file from the OL Connect File Store, using either a file name or File Store ID.
The task requires either the name of the file in the OL Connect File Store or its File Store ID.
The name of a file is chosen and its File Store ID is returned when uploading it with the File Store - Upload File task.
The task requests removal of the file by performing a call to the /rest/serverengine/filestore/delete/{fileId} REST endpoint; see File Store Service: Delete File in the REST API Cookbook.
This task has no impact on the current Job File.
  • File name/ID: The name or the ID of the file to delete.
OL Connect Proxy Tab
This tab is common to all OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect preferences.
  • OL Connect Proxy Address: Enter the machine name or IP Address where the OL Connect Server resides.
  • Port: Enter the port to use to communicate with the OL Connect Server. Default: 9340
  • User name: Enter the user name expected by the OL Connect Server.
  • Password: Enter the password expected by the OL Connect Server for the above user name.
