Australia Post, Japan Post, KIX, USPS IMb
Australia Post, Japan Post, KIX and USPS IMb are some of the types of barcodes that can be added to a template; see Barcode.
In OL Connect versions prior to 2019.2 the USPS IMb barcode was called "OneCode".
Note that barcodes of these types don't process tilde characters (~) in the data as special characters.
This topic lists the properties and output options of the barcode types Australia Post, Japan Post, KIX and UPS IMb. For the properties of other barcode types, see Barcode type and properties.
Tip: A KIX code can also be part of an address block created by the Address Block wizard. See Address Block.
Barcode properties
Height, width and spacing
  • Bar height: The height of the (shorter) bars.
  • Extended bar height: The total height of the extended bars.
  • Bar width: The width of the bars.
  • Spacing: The distance between the bars.
Scale
  • Proportional: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Barcode output
Color
Output format
  • SVG: Vector format. This is usually of higher quality, but may take longer to generate. It is not compatible with Email output.
  • PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster. It will display properly in Email output.
