data
Returns a data object encapsulating properties and methods pertaining to the original data stream.
Properties
The following table lists the properties of the data object.
Property Description Return type
filename
The path of the input file.
Returns the fully qualified file name of the temporary work file being processed.
properties
Contains properties declared in the preprocessor step (see Preprocessor Step Properties for details).
Returns an array of properties defined in the Preprocessor step with the data scope (i.e. statically set at the start of the job).
Methods
The following table lists the methods of the data object.
Method Description Script type File type
extract()
Extracts the text value from a rectangular region.
Extract, Condition, Repeat, and Action steps
All
extractMeta()
Extracts the value of a metadata field.
All
fieldExists()
Method that returns true if the specified metadata field, column or node exists.
Boundaries
Preprocessor, Extract, Condition, Repeat, Action, and Postprocessor steps
All
find()
Finds the first occurrence of a string starting from the current position.
Boundaries
All
findRegExp()
Finds the first match for a regular expression pattern starting from the current position.
Extract, Condition, Repeat, Multiple Conditions and Action steps
Text, PDF
  • Last Topic Update: 29, June, 2017 10:44 AM
