Job Creation Presets
The Job Creation Setting dialog displays a list of available presets and a summary of their settings. Presets can also be edited from this dialog.
  • Data Mapping Configuration: Use the drop-down to select which data mapping configuration this job creation preset will be based on. The data mapping configuration's model is used for field names in sorting, etc.
  • Configuration Name: Use the drop-down to select the presets saved in the default location Click the Gear icon for more options:
    • Click the Reload option to look for new presets.
    • Click the Import Configuration... option to import one or more Job Presets using a Browse dialog.
  • Properties: Displays a summary of the settings for this Job Creation Preset.
  • Options Group: These options are checked, or not, depending on the selected preset chosen in the Configuration name.
  • Next: Click to go to the next page of the Job Creation Wizard, Data Filtering Options
  • Finish: At any point during the wizard, click to save the current configurations, whatever page you are on.
  • Cancel: At any point during the wizard, click to exit the wizard without saving changes.
  • Last Topic Update: 13, April, 2016 10:11 AM
  • Last Published: 2019-05-23 : 3:20 PM
