createRegion()This method sets the physical coordinates of the PDF and Text: createRegion(x1, y1, x2, y2)Creates a region from the data, using the specified left (x1), top (y1), right (x2) and bottom (y2) parameters, expressed in characters for a text file or in millimeters for a PDF file. x1 Double that represents the left edge of the region. y1 Double that represents the top edge of the region. x2 Double that represents the right edge of the region. y2 Double that represents the bottom edge of the region. ExampleThe following script attempts to match
(The match() function expects a regular expression; see w3schools.) CSV or database: createRegion(columnName)Creates a region from the data in a CSV file, using the specified columnName parameter. columnName String containing the name of the column where the region is to be created. ExampleThis script checks the first value in a certain column. If it is not the same value as in the previous record(s), a document boundary is set.
