| found |
Field that contains a boolean value indicating if the last call to boundaries.find() was successful. Since the find() method always returns a region, regardless of search results, it is necessary to examine the value of found to determine the actual result of the operation.
Boolean |
range
Read-only object containing the physical coordinates of the region.
Physical location of the region: x1 (left), y1 (top), x2 (right), y2 (bottom), expressed in characters for a text file or in millimeters for a PDF file. For a CSV file, it is the name of the column that defines the region.
createRegion()
Creates a region by setting the physical coordinates of the region object.
A region that has the specified coordinates.
