Data mapping configurations
A data mapping configuration file contains the information necessary for data mapping: the settings to read the source file (Delimiter and settings), the data mapping workflow with its extraction instructions ('Steps'), the Data Model and any imported data samples.
Data mapping configurations are used in the Designer to help add variable data fields and personalization scripts to a template. In fact, only a Data Model would suffice (see Importing/exporting a Data Model). The advantage of a data mapping configuration is that it contains the extracted records to merge with the template, which lets you preview a template with data instead of field names. It is also possible to generate output of a data mapping configuration directly from the Designer (see Generating output).
Ultimately data mapping configurations are meant to be used by the Execute Data Mapping task in Connect Workflow processes, to extract data from a particular type of data file. Typically the extracted data is then merged with a template to generate output in the form of print, email and/or a web page. To make this happen, the data mapping configuration as well as the template and any print presets have to be sent to Workflow; see Sending files to Workflow.
Creating a new data mapping configuration
A new data mapping configuration can be made with or without a wizard. When you open a data file with a wizard, the wizard automatically detects a number of settings. You can adjust these settings. Next, the wizard automatically extracts as many data fields (or metadata, in case of a PDF/VT or AFP file) as it can, in one extraction step. Without a wizard you have to make the settings yourself, and configure the extraction workflow manually.
The DataMapper doesn’t use the data source directly, rather it uses a copy of that data: a . Although the data sample is a copy, it is updated each time the data mapping configuration is opened or whenever the data sample is selected. More samples can be added via the Settings pane; see Data samples.
From a file
To start creating a data mapping configuration without a wizard, first select the data file. There are two ways to do that: from the Welcome screen and from the File menu.
- From the Welcome screen
- Click Create a New Configuration.
- From the From a file pane and select a file type:
- Comma Separated Values or Excel (CSV/XLSX/XLS),
- Microsoft Access
- PDF, PS, PCL or AFP
PCL and PostScript (PS) files are automatically converted to PDF
format. Some advanced PCL to PDF options are available by calling LincPDF ( PlanetPress Connect's PCL to PDF converter) command line module. - Text
- XML.
- Click the Browse button and open the file you want to work with (for a database, you may have to enter a password).
- Click Finish.
From the File menu
- Click the File menu and select New.
- Click the Data mapping Configuration drop-down and select Files and then the file type:
- (MS Access) MDB
- XML.
- Click Next.
- Click the Browse button and open the file you want to work with.
- Click Finish.
After opening the file, you have to make settings for the input data (see Data source settings). Then you can start building the data extraction workflow.
- In a production environment (a Connect Workflow process) the automatic conversion of PCL or PostScript (PS) may influence the processing speed, depending on the available processing power.
- Excel files saved in "Strict Open XML" format are not supported yet.
- Extracting data from a PDF that comes from a Windows printer queue (a PDF converted to PostScript, converted back to PDF by an Input task in Workflow) might not work (see the Connect Knowledge Base). The rule of thumb is: if copy-paste from Acrobat works, so will data mapping; if not, the DataMapper won't either.
With a wizard
Data mapping wizards are available for PDF/VT, AFP, XML, CSV and database tabular files, because these files are structured in a way that can be used to automatically set record boundaries. The wizard for PDF/VT and AFP files cannot extract data, only metadata. After opening such a file with the wizard, you can build the data extraction workflow. The other wizards use the Extract All step to extract data, but they cannot create detail tables, so they are less suitable for files from which you want to extract data.
There are two ways to open a data file with a wizard: from the Welcome screen or from the File menu.
- Open the PlanetPress ConnectWelcome page by clicking the
icon at the top right or select the Help menu and then Welcome. - Click Create a New Configuration.
- From the Using a wizard pane, select the appropriate file type.
- From the File menu
- In the menu, click File > New.
- Click the Data mapping Wizards drop-down and select the appropriate file type.
The steps to take with the wizard depend on the file type. See:
Generating a counter
Instead of creating a data mapping configuration for a certain type of data file, you may create a data mapping configuration that only contains a series of sequential numbers. This is a solution if, for instance, you need to create sequential tickets or anything that has an ID that changes on each record.
You can’t join this configuration to another data file. It is just a counter to be applied on a static template.
To generate a counter:
- From the Using a wizard pane, select Generate counters.
- Click the Data mapping Wizards drop-down and select Generate counters.
You can set the following parameters:
- Starting Value: The starting
number for the counter. Defaults to 1.
- Increment Value: The value
by which to increment the counter for each record. For example, an
increment value of 3 and starting value of 1 would give the counter
values of 1, 4, 7, 10, [...]
- Number of records: The
total number of counter records to generate. This is not the end value
but rather the total number of actual records to generate.
- Padding character: Which
character to add if the counter's value is smaller than the width.
- Width: The number of digits
the counter will have. If the width is larger than the current counter
value, the padding character will be used on the left of the counter
value, until the width is equal to the set value. For example for
a counter value of "15", a width of "4" and padding
character of "0", the value will become "0015".
- Prefix: String to add before
the counter, for example, adding # to get #00001. The prefix length
is not counted in the width.
- Suffix: String to add after
the counter. The suffix length is not counted in the width.
Opening a data mapping configuration
To open an existing data mapping configuration, in the Menus, select File > Open. Make sure that the file type is either DataMapper files or Connect files. Browse to the configuration file to open, select it and click Open. Alternatively, click on File > Open Recent to select one of the recently opened configuration files.
Saving a data mapping configuration
A Data Mapping Configuration file has the extension .OL-datamapper. The file contains the settings, the extraction workflow ('Steps'), the Data Model and the imported Data Samples (excluding database
source files such as mySQL, oracle, etc).
To save a data mapping configuration:
- In the Menus, click on File > Save, or click on Save As to save a copy of a data mapping configuration under a different name.
- In the Toolbars, click the Save button.
If the data mapping configuration has not been saved before, you have to browse to the location where the data mapping configuration should be saved and type a name, then click Save.
