Using the wizard for XML filesThe DataMapper wizard for XML files helps you create a data mapping configuration for an XML file. The wizard lets you select the type of node and the trigger that delimit the start of a new record. Next, the wizard extracts the data in one extraction step. The wizard cannot create detail tables. If the file contains transactional data, the data mapping configuration is best created without a wizard (see Creating a new data mapping configuration). There are two ways to open an XML file with a wizard: from the Welcome screen or from the File menu.
After selecting the file, you have to set the split level and trigger type:
The DataMapper only extracts elements for which at least one value is defined in the file. Attribute values are not taken into account.
Attribute values (prefixed with an @ sign in the Data Viewer) are not extracted automatically. Click Finish to close the dialog and open the data mapping configuration. |
