Additional Content
The Additional Content page allows you to add content at the time of printing. There are four different types of Additional Content that can be added at print time: Text; Images; Barcodes and OMR Marks. They can be used to add either static content or variable content.
The Additional Content option is particularly useful when you might need to drive custom
processes on production machines using either Barcodes or OMR Marks, or if you need to add some last minute additions
to the print job via text and/or images.
Page breakdown
The Additional Content table displays any Additional Content that has been set. Additional Content can be added, edited, removed, duplicated or moved within the table via the buttons to the right of the table.
The Additional Content options are:
Add: Click to open some Additional Content. The choices are as follows:
Edit: Click to edit the
currently selected entry. This will launch the appropriate edit box, for the selected entry type. Double clicking on an entry in the table has the same effect as this button.
Delete: Click to delete
the currently selected entry or entries.
Duplicate: Click to create
a duplicated copy of the entry. This creates a new entry that is exactly the same as the original.
/ Move Up / Move Down: Click to move the selected entry (or entries) up or down within the table.
Additional Content Table: The table is split up into the following columns
- Preview button: Click to launch a Proof Preview window, which displays how the printed output would look based upon the currently chosen selections.
- Back and Next buttons: Used to navigate back and forth through all the selected options within the Wizard. Up until the Print button is pressed, one can reverse all the way through the wizard to return to the main selection page (the Print Options page) and add or remove printing options from the print run.
- Print button: Click to produce print output according to the current settings. This can be done at any point within the Wizard, whether or not all the options selected in the Print Options page have been completed or not.
- Cancel button: Cancels the Print Wizard, without creating any printout.
