Additional Barcode OptionsWhen adding Barcodes
in the Additional Content
page you can select from a series of predetermined Barcode types. To create dynamic barcodes, Metadata options must first have been set. Metadata fields are required to create the association between the dynamic data used in the print run and the barcode.
The options for each of these types is described on the following pages:
