Table Formatting dialog
The Table Formatting dialog defines how a table looks. Note that the settings are applied to the table as a whole. For example, when you change the border of the table, the borders of cells inside the table will not be changed. For more information see Styling a table.
All settings in this dialog are in fact CSS properties. Cascading Style Sheets (CSS) were originally designed for use with web pages: HTML files. Since Designer templates are HTML files, they are styled with CSS. To learn how to use CSS in the Designer, see Styling and formatting and Styling templates with CSS files. For information about specific properties and their options, see W3Schools CSS Reference.
Table Tab
- General group:
- Width: Set the width
of the table in measure or percentage. Equivalent to the CSS
widthproperty. - Height: Set the height
heightproperty. - Angle: Set the rotation
angle of the table in clockwise degrees. Equivalent to the CSS
transform:rotateproperty. - Corner radius:
Set the radius of rounded border corners in measure or
border-radiusproperty. - Display: Use the
drop-down or type in the value for how to display the table.
Equivalent to
the CSS
displayproperty. - Overflow: Use the
drop-down or type in the value for how to handle overflow
(text that does not fit in the current size of the box). Equivalent to the CSS
overflowproperty.
- Text wrap group:
- Float: Use the
drop-down or type in the value for how to float the table, if
the table is not in an absolute position. Equivalent to the CSS
floatproperty. - Clear: Use the
drop-down or type in the value for clearing pre-existing alignments.
Equivalent
to the CSS
clearproperty.
- Float: Use the
- Positioning:
- Position: Use the
drop-down or type in the value for the type of positioning
for the table. Equivalent to the CSS
positionproperty. - Top: Set the vertical
offset between this table and its parent's top position. Equivalent
to the CSS
topproperty. - Left: Set the horizontal
offset between this table and its parent's left position. Equivalent
to the CSS
leftproperty. - Bottom: Set the
vertical offset between this table and its parent's bottom position.
bottomproperty. - Right: Set the
horizontal offset between this table and its parent's left position.
rightproperty. - Z-index: Set the
z-index of the table. The z-index defines in which order elements appear. Equivalent
to the CSS
z-indexproperty.
- Position: Use the
- Breaks group:
- Before: Specifies
how to handle page breaks before the table. Equivalent to
the CSS
page-break-beforeproperty. - Inside: Specifies
whether to accept page breaks within the table. Equivalent
to the CSS
page-break-insideproperty. - After: Specifies
how to handle page breaks after the table. Equivalent to
the CSS
page-break-afterproperty. - Widows: Specifies
how to handle widows within the table (rows appearing alone
on the next page if the table does not fit on the current
one). Equivalent to the CSS
widowsproperty. Widows and orphans are ignored if thepage-break-insideproperty is set toavoid. - Orphans: Specifies
how to handle orphans within the tables (rows appearing alone
at the end of a page if the table does not fit on the current
orphansproperty.
- Before: Specifies
the CSS
- Padding group: Defines
padding (spacing inside the element) in measure or percentage:
- All sides: Check to
set all padding to use the Top value. Equivalent to the CSS
paddingproperty. - Top, Left, Bottom, Right:
Set padding for each side. Equivalent to the CSS
padding-left,padding-top,padding-rightandpadding-bottomproperties.
- Margin group: Defines margins (spacing outside the element) in measure or percentage:
set all margins to use the Top value. Equivalent to the CSS
marginproperty. - Top, Left, Bottom, Right:
Set the margin for each side. Equivalent to the CSS
- Same for all sides:
Defines
the border properties for all sides using the Top properties. Equivalent
to the CSS
borderproperty. - Top, Left, Bottom, Right:
Each group defines the following properties:
- Width: Specify the
thickness of the border. Equivalent to the CSS
border-widthproperty. - Style: Specify the
style of the border such as
solid,dashedordotted. Equivalent to the CSSborder-styleproperty. - Color: Specify the
color of the border: select a named color (defined in the Colors Editor) from the drop-down, or click the colored square to open the Color Picker dialog (Color Picker). Alternatively you could type a name or value in the Color field directly. It must be a predefined CSS color name (CSS color names), a hexadecimal color code (HTML Hex Color), an RGB color value, for example
rgb(216,255,170)or a CMYK color value, for examplecmyk(15%, 0%, 33%, 0%).
Equivalent to the CSSborder-colorproperty.
- General group:
- Color: Specify the color of the table background:select a named color (defined in the Colors Editor) from the drop-down, or click the colored square to open the Color Picker dialog (Color Picker). Alternatively you could type a name or value in the Color field directly. It must be a predefined CSS color name (CSS color names), a hexadecimal color code (HTML Hex Color), an RGB color value, for example
Equivalent to the CSSbackground-colorproperty.
- Background image group:
- Source: Click the Select Image button to select an image via the Select Image dialog. Equivalent to the CSS
backgroundproperty. - Size: Select
auto,coverorcontain(for an explanation see https://www.w3schools.com/cssref/css3_pr_background-size.asp), or type the width and height of the image in a measure (e.g.80px 60px) or as a percentage of the parent element's size (e.g.50% 50%). Equivalent to the CSSbackground-sizeproperty. - Position: Select the position for the background-image. Equivalent to the CSS
background-positionproperty.
Spacing Tab
For information about spacing see Spacing.
Border Tab
For information about borders see Border.
Background Tab
For information about backgrounds see Background color and/or image.
