Description: |
+ Add |
operator function |
Adds two numerical expressions. This is the functional equivalent to the + operator, when you use the + operator with numerical expressions.Add (function) |
– Sub |
operator function |
Subtracts one expression from another. This is the functional equivalent of the - operator.Sub (function) |
* Mul |
operator function |
Multiplies two expressions. This is the functional equivalent of the * operator.Mul (function) |
/ Div |
operator function |
Divides an expression with another. This is the functional equivalent to the / operator.Div (function) |
Mod |
function & procedure |
Returns the remainder resulting from the division of two numbers.Mod (function & procedure) |
– Neg |
function |
Returns the negative value of the specified expression. This is the functional equivalent to the - sign.Neg (function) |
Cos |
function |
Returns the cosine value of the specified angle.Cos (function) |
Sin |
function |
Returns the sine value of the specified angle.Sin (function) |
Random |
function |
Returns a measure value between 0 and 1, non-inclusive. Since this function uses the current system time when run inside the printer, it returns a true random value. On the computer, however, the function uses the current data page as its seed to ensure the returned value is constant when you navigate from page to page on your document.Random (function) |
Ceil |
function |
Returns the smallest integer greater than or equal to the specified measure value. Ceil (function) |
