Description: |
BeginUTF8Paragraph … EndUTF8Paragraph |
procedure |
Delimits a paragraph of formatted UTF8 text.BeginUTF8Paragraph … EndUTF8Paragraph (procedure) |
MapUTF8 |
function |
Converts a text string from its original encoding to UTF8.MapUTF8 (function) |
ShowUTF8 |
procedure |
This command is used to display UTF8 text on the document.ShowUTF8 (procedure) |
ShowUTF8Left / ShowUTF8Right / ShowUTF8Center |
procedure |
These three commands are used to display simple text strings on the document. ShowUTF8Left / ShowUTF8Right / ShowUTF8Center (procedure) |
When using PlanetPress Talk code to perform a line repeat directly on an object, use the reserved word ¤titeration. The value of the iteration will increment. You can also repeat on a group using the syntax &group.currentiteration.
