7.67.52015-05-06
PlanetPress Talk Before and After
The properties for all documents, pages and objects contain two sections named "PlanetPress Talk Before" and "PlanetPress Talk After", which are used to execute PlanetPress Talk code before or after the object is displayed on the page.
Specific variables are available within these boxes that can be used to obtain data about the object and to modify it, for example for height, width and position. For more information, see the PlanetPress Talk Reference Guide.
Any object that has PlanetPress Talk code entered in either the "Before" or "After" section will be identified in the Document Structure area in a maroon color instead of the normal black text. This color may be different and is configurable in the Color Preferences. It is the same color as PlanetPress Talk-enabled boxes.
