), then click the Scheduler button. From the Automation Configuration screen, use the Start/Stop Automation Session slider to start and stop automation processing.
When you stop automation from the automation configuration screen or the automation tray icon, all automated jobs will stop processing. If there are any automated jobs currently being processed, a warning window appears indicating that they will be cancelled. Click Yes to stop theses jobs or Cancel to let the jobs continue and automation mode to remain active.
From the Automation Configuration screen, use the Pause/Resume Automation Session slider to pause and resume automation. When you pause automated jobs, they will remain in the buffer and resume as soon as you resume automation.
button next to the Automated Jobs list. A new line is added to the Automated Jobs list.You can add as many automated jobs as you want.
Automated jobs will run simultaneously. The number of jobs that run at the same time depends on your computer and is equal to the number of processors (or core) available in the CPU.
button.When you select a folder with Browse... in the Automated Jobs screen, the PlanetPress EnvelopeNOW automation will watch this folder and capture any file that is sent to this folder. However, some limitations are present:
Make sure that no other software or processes are trying to capture the files in the same folder as PlanetPress EnvelopeNOW. For example, do not try to configure a process in PlanetPress Workflow Tool to capture from the same folder. This will cause unexpected and undesired behaviours.
When you select a printer name in the Automated Jobs screen, the PlanetPress EnvelopeNOW automation will capture any job sent to this printer from any application. However, some limitations are present:
For these reasons, we strongly suggest using the EnvelopeNOW Printer, which was installed at the same time as PlanetPress EnvelopeNOW, to capture your jobs.
If an error occurs during processing for any reason, the file that caused the error will be sent directly to an error folder that is located in your computer under My Document/PlanetPress EnvelopeNOW/Error. The PDF File can be reprocessed either by placing it in a monitored folder, or by using the Print Job option from the PlanetPress EnvelopeNOW Home Screen.
