2011-07-29
Select a configuration file and sample document
A step-by-step animation of this section is available online by clicking here.
Hardware Configuration selection
The Select a Hardware Configuration box shows a list of hardware configurations that have been installed on your system and are currently active. Click on any of the hardware configurations in the list to select it. If your hardware configuration does not appear or if you want to remove hardware configurations you do not use, please refer to Configuration.
Fold Type selection
Click on the Select a Fold Type box to display a drop down menu that lists the available fold types supported by the chosen hardware. Click on the one you want to use.
Sample File
Click on the Select a Sample File box to display a drop down menu that lists all of the printers installed on your system as well as the Browse... option.
Certain limitations apply to printer data capture. See Technical Considerations.
