To access the preferences screen click on the
button from the home screen. Once you are done changing the options, click on the Apply button to save and close the preferences.
Here are the tabs and options available in the Preferences screen:
Here you can change the language of the application, as well as configure if you want the drop-down menus to automatically drop down in the application.
The new language will only take effect when you restart the application.
For more information, see Automation configuration screen
Change the data capture Mode drop-down to set PlanetPress EnvelopeNOW to execute any data capture from a printer queue using specific user logon rights:
For more information on user modes and data capture limitations, please see Technical Considerations.
This section lists all of the hardware configuration files that are installed on your system. Click on the check mark next to any configuration to select or deselect it.
For more information see Hardware Configurations
This screen displays information about the software, as well as the status of your activation. The Version area displays the current version of the software. The Serial number is also displayed along with your activation status.
