You can copy the information that appears in the Results list to the Windows Clipboard, for subsequent pasting into an external application. For example, you might copy the information and paste it into an email message or Word® document.
You can copy the information for one, some, or all of the search results. When you copy information for a search result, PlanetPress Search copies all the information that appears in the Results list for that search result. You cannot restrict the copy to only part of the information for a search result.
To copy information from the Results list:
If you performed a search on all documents in the database, expand the document in the Results area that you want to select search results from.
Select one or more search results in the Results list. See Select Search Results if necessary.
Choose Edit | Copy Row Data or right-click in the Results list and choose Copy Row Data.
PlanetPress Search copies the information for each of the selected results to the Windows Clipboard.
In an external application, use the Paste command to paste the contents of the Windows Clipboard into that application.
