The Process areaThe Process area, which is always available and visible, holds all the tasks, branches, conditions and comments that make up the selected process (see About processes and subprocesses and About Tasks). The Process area is built like an invisible grid divided by rows (horizontal) and columns (vertical). When adding a new Action task, a new row is added. When adding a Branch or Condition, a new column appears (unless there is already a column at that level). The Process area is where you edit a process by:
In the Process area you can also: |
