Note to PlanetPress Suite users: the following content only applies to PlanetPress Connect.
Create Output
The Create Output task generates Print output in a format specified by a Connect Print Preset and sends this output to the appropriate target location.
See also: About printing.
This task can be added as an Action task (see Action Tasks) or as an Output task (see Output Tasks). Adding it as an Action task enables the process or branch to continue after this task. An Output task is always located at the end of a process or branch.
When added as an Output task, the Create Output plugin works asynchronously to the Workflow process.
The task requires a valid Job Metadata file, normally output from a Create Job or Merge Jobs task.
The job is sent to the OL Connect Server for processing.
Depending on the options set, either a simple metadata file with information about processing is returned, or the actual output file created by the server.
Properties
The Create Output task properties are as follows:
  • Output Preset file: Select which Output Preset to use to generate the output. To be used in this dialog, a preset must have been sent to PlanetPress Workflow using the Package File function in PlanetPress Connect.
    • "%o": Select to use a dynamic preset name. Click on %o to change the expression that determines the name of the preset to use. The preset name must be available in the list below.
    • Preset Names: Select the appropriate preset to generate output.
  • Output Management group:
    • As defined by Output Preset: Select to send the output of the job to the location set in the Print Preset (file, printer, etc).
    • Through Workflow: Select to replace the current job file with the output produced by the server. Every option in the Output Preset is still used, except for the output location.
      Note that when the output is separated, the current job file is not replaced with the actual output files but with a CSV file that lists the paths to the outputted files (e.g. “C:\Users\Administrator\Connect\filestore\3836.2859982401376467470\template_0001.pdf,C:\Users\Administrator\Connect\filestore\3836.2859982401376467470\template_0002.pdf,…”).
OL Connect Proxy Tab
This tab is common to all OL Connect tasks and defines where to process the jobs sent through these tasks. When these fields are empty, they use the defaults set in the OL Connect User Options page of the preferences.
Defaults are not used unless the configuration is sent to the Workflow service.
  • OL Connect Proxy Address: Enter the machine name or IP Address where the OL Connect Server resides.
  • Port: Enter the port to use to communicate with the OL Connect Server. Default: 9340
  • User name: Enter the user name expected by the OL Connect Server.
  • Password: Enter the password expected by the OL Connect Server for the above user name.
Comments Tab
The Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane.
  • Last Topic Update: Aug-21-2018 - 09:08
