Note to PlanetPress Suite users: the following content only applies to PlanetPress Connect.
Merge Jobs
The Merge Jobs Action task merges an external Metadata file containing an OL Connect Job with the current Job File.
The task must receive a Metadata Job File, which is output from the Create Job task. The selected Metadata file must also be the output of a Create Job task.
The current Metadata Job File is merged with the selected external Metadata file.
The task outputs a merged Metadata Job File which can be used in the Create Output task.
  • Metadata file: Enter the full path to a valid Metadata file containing an OL Connect Job, or use the Browse button to browse to a valid location.
Comments Tab
The Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane.
  • Last Topic Update: Aug-21-2018 - 09:08
