Standard Filter
Standard Filter Action tasks can be used to remove HP Escape characters from data files, as well as to eliminate spacing problems caused by LF-CR end-of-line sequences.
HP escape characters are used in the Hewlett Packard Printer Control Language (HP PCL) to communicate basic page formatting and font selection information from print jobs to HP or HP-compatible printers.
These characters, like other printer control characters that control how printers interpret and print jobs, are not meant to be printed.
If your print job is bound for an HP compatible printer, it may include these characters even when printing to a PostScript printer that does not recognize them. PlanetPress Workflow provides an easy way to automatically filter these characters through its Standard Filter task.
Text-based data files such as line printer data (see Line printer emulation) and ASCII data files (see ASCII emulation) data files, which contain HP PCL control characters.
All HP PCL characters are removed from the data file. Note that these characters are not interpreted, only stripped out.
The modified data file, with stripped characters, is output from this task. Metadata, Job Info variables and other variables are not modified.
  • Process job using ASCII emulation: Select to use the ASCII emulation to process the job file. This reverses LF-CR end-of-line sequences that may result in unwanted double-spacing.
  • Remove and convert HP escape characters: Select to filter HP escape character sequences from the job file.
Comments Tab
The Comments tab is common to all tasks. It contains a text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in the Task Comments Pane.
  • Last Topic Update: Aug-21-2018 - 09:08
