8.17.52015-05-05
Manipulate Local Variables
For information about Global Variables see Global Variables.
Local Variables are set at the level of the Process and are not shared with any other process or instance of that process. Local variables can be used anywhere that accepts variables by using it's namee, surrounded by curly brackets and preceded by a percent sign (for example: %{myLocalVariable}).
When the process ends, the local variable forgets whatever value was given to it by the process and goes back to its default value. Local variables are generally used to keep information that is useful for the process itself but not to any other process or instance of the process. For example, you could store the current order ID for the process, a name or an email. You can have as many local variables as you want in any given process.
To add a local variable, you can use one of two methods:
Shared tasks
These procedures can be used on both local and global variables.
To delete a variable
To rename a variable:
While renaming a variable will correctly rename all references to it in task properties or wherever else it is used in a task, it will not change the references in any script within a Run Script task. Deleting a variable, on the other hand, does not delete any reference to it. In both the case where a script refers to a variable and it is renamed, or in the case of deleting a variable, any task or script that refers to it will cease to function and will generate an error.
You can set the value of a variable within your process in two ways:
Variables may be used as variable properties in variable property boxes (see Variable Properties).
