8.17.52015-05-05
Capture Condition
The Capture Condition checks the status or field contents of a capture document that has been processed by the Capture Field Processor action task.
A data file in PGC or PDF format that is accompanied by valid Metadata. This metadata must contain Capture information and is generally available after a Capture Fields Processor or Find Capture Documents task. However, it is also possible to directly retrieve the required information from a specific Document ID. When a specific ID is used, the data file and metadata are completely ignored by this task's condition rules, and the database information is used instead.
The condition is evaluated using the specified rules, combination (condition is true when...) and scope (condition scope).
The original data file and metadata is output by this task. If the rules used in the condition return True, the data and metadata is sent down in the condition's branch. Otherwise, this same information is sent in the trunk.
Task Properties
Examples & Use Cases
Common Errors
Comments Tab
