8.17.52015-05-05
Find Capture Documents
The Find Capture Document task retrieves a list of pertinent information about Capture documents present in the Capture Database according to a specified set of rules.
This task is most often useful as the beginning of an automated process using a series of Capture documents, for example one that removes old documents to unlock patterns. However, it can also be used as a secondary input in order to retrieve one or more documents after some operations.
Because this task in an Input task, it does not use the current job file in your process, even when used as a secondary input task.
This task connects to the Capture database and looks up all available documents that meet the criteria specified in the plugin. Then it does further processing to retrieve relevant information about each document and places the information in the data file it generates.
The data file generated by this task is an XML structure containing the data about each document. It also generates metadata that is compatible with post-processing tasks such as the Capture Condition and Get Capture Document tasks.
This metadata includes:
Task Properties
The Advanced Data File option will generate a high number of queries into the Capture Database, and will be slower than a regular data file by orders of magnitude. Do not use this option unless you are aware of the loss of performance and actually need to access each field's properties individually!
Examples & Use Cases
Common Errors
Comments Tab
