8.17.52015-05-05
Get Capture Document
The Get Capture Document action task is used after the Capture Field Processor to retrieve all documents that have been updated.
A data file in PGC or PDF format that is accompanied by valid Metadata. This metadata must contain Capture information and is generally available after a Capture Fields Processor or Find Capture Documents task. However, it is also possible to directly retrieve the required information from a specific Document ID. When a specific ID is used, the data file and metadata are completely ignored by this task's condition rules, and the database information is used instead.
One PDF, corresponding to the information present either in the metadata or specified in the task, is extracted from the Capture database.
When retrieving documents from the database, the PDF from which the document is obtained will remain in the database until each document contained in it is retrieved from it. For example, if a 10-page PDF contains 5 documents, the 10 pages remain in that PDF until all 5 documents have received ink, been closed and retrieved from the database. This may mean space issues if too many PDF files remain in your database.
Performance-wise, when this plugin retrieves a document from a 10,000 page PDF in the database, it will take more time then if it retrieved it from a 100 page PDF.
The Get Capture Document action task is a loop that outputs a PDF version of the Capture Document. The PDF contains the original document, any ink added by the Capture Fields Processor action task.
In addition, any ICR information available (when using PlanetPress Capture ICR) will be placed at the Page Level, as follows:
Task Properties
Examples & Use Cases
Common Errors
Comments Tab
