8.18/6/2018
Adding Branches
The PlanetPress Workflow Configuration program offers two different commands when it comes to adding new branches to a process:
You can add a new branch, by dragging and dropping a branch, from the Process Logic category of the Plug-in Bar, into your process. Branches can be added using the Adding Tasks method.
You can add a new branch that contains all of the tasks below the point where you insert the branch. To do this, right-click on the first task that you want to include in the branch, and select Branch From Here... . An unknown task will be created as an output below the branch.
