8.18/6/2018
PDF Splitter
PDF Splitter action tasks are used to split emulated PDF data files into multiple data files that are passed to subsequent tasks in the process.
This feature is part of the PDF Tools, which is only available in PlanetPress Office and PlanetPress Production. It is not available with a PlanetPress Watch license.
A PDF Emulation data file.
The file is separated into multiple chunks according to the rules set in the task's properties.
Multiple data files, sent one after the other to the rest of the tasks in the process. Metadata, job infos and user variables are not modified by this task.
PDF Splitter action task properties are as follows:
Common Errors
Comments Tab
