The PlanetPress Button
The PlanetPress Button replaces the File menu from previous versions, and provides access to the File menu options. The color of the button itself can show you at a glance what flavor of PlanetPress Workflow is currently licensed on the machine: Yellow for Watch, Light Orange for Office, Dark Orange for Production.
The available menu options of the PlanetPress Button are:
- New: Closes the configuration that is currently opened and creates a new configuration, with a single example process and no printer queues. See Create a New Configuration.
- Open: Displays the dialog to open an existing configuration file.
- Save: Saves the current configuration. If the file is new and has not yet been saved, or if the configuration is the loaded directly from the service, the Save As dialog is displayed instead. See Save your Configuration.
- Save As: Saves the current configuration under a new name. It does not overwrite any existing configuration file, unless an existing file is selected and overwritten manually by the user.
- Import:
- Configuration Components: Displays the Import Processes dialog, letting you import processes and other components from other existing configuration files. See Import Processes from Another Configuration File.
- PlanetPress Document: Displays the dialog to import a PlanetPress Document to be added to the list in the components area.
- PrintShop Mail Document: Displays the dialog to import a PrintShop Mail Document to be added to the list in the components area.
- Send Configuration: Sends the current configuration to the PlanetPress Watch service. See Send your Configuration.
- Close: Closes the configuration that is currently opened and creates a new configuration, with a single example process and no printer queues. Closing the current configuration is the same as creating a new one.
- Recent Documents: Displays a list of the 9 most recently opened configuration files. Click on any of them to open it.
- Select Language: Click to display the language selection dialog, which changes PlanetPress Workflow interface language. See
Change the Interface Language.
- Preferences: Displays the Options dialog. See Preferences.
- Exit: Closes PlanetPress Workflow. See
Exit PlanetPress Workflow Configuration Program.
When using the New, Open, Close, Recent Documents and Exit menu options, if your current configuration has not been saved after modifications, a dialog will open asking if you want to save, not save, or cancel the action and return to the current configuration.
