When you start PlanetPress Workflow, it always opens the configuration file that is active on the PlanetPress Watch service (ppwatch.cfg). If you create a new configuration, PlanetPress Workflow automatically creates a process that includes a Folder Capture initial input task and a Send to Folder output task. You can then edit and save your new configuration.
To create a new configuration, choose New from the PlanetPress Button.
If the active ppwatch.cfg file is currently opened, and if it includes unsaved modifications, PlanetPress Workflow asks you whether to send the configuration to the PlanetPress Watch service before creating the new configuration. Select the Always send without prompting for confirmation option to automatically send the edited version of the configuration.
If a file different from the default configuration file is currently opened, and if it includes unsaved modifications, PlanetPress Workflow asks you whether to save the configuration before creating the new configuration. Select the Always save without prompting for confirmation option to automatically save any unsaved work.
