8.18/6/2018
Manipulate Global Variables
For information about Local Variables see Local Variables.
Global Variables are set at the level of the Configuration file and are shared between all processes and tasks. Global variables can be used anywhere that accepts variables by using it's name preceded by "global." and surrounded by curly brackets (for example: %{global.myGlobalVariable}).
Global variables are generally used to keep information that applies to multiple locations but need to be changed easily. For example, a lot of uses use them to set a server's IP, a printer name, or folder location that is used by multiple processes. This is useful when moving the configuration file to another installation of the Workflow Tools where this information is different, or to quickly modify specific information if something changes on the server. You can have as many global variable as you want in any given configuration.
To add a global variable from the Configuration Components Pane:
  1. Right-Click on Global Variables
  2. Click Insert, then Insert Global Variable.
    The new variable will appear as GlobalVar or GlobalVarX (the name is automatically incremented).
To add a global variable from the Ribbon:
  1. Click on the Home tab of the PlanetPress Suite Ribbon
  2. Click Global Variable in the Variables group.
To set the value of a global variable from the Configuration Components Pane:
  1. Double-click on the global variable in the Configuration Components Pane.
    (Right-clicking then clicking Properties also works)
  2. Enter the new value for your global variable
  3. Click OK to save the new value.
Shared tasks
These procedures can be used on both local and global variables.
To delete a variable
To rename a variable:
While renaming a variable will correctly rename all references to it in task properties or wherever else it is used in a task, it will not change the references in any script within a Run Script task. Deleting a variable, on the other hand, does not delete any reference to it. In both the case where a script refers to a variable and it is renamed, or in the case of deleting a variable, any task or script that refers to it will cease to function and will generate an error.
You can set the value of a variable within your process in two ways:
Variables may be used as variable properties in variable property boxes (see Variable Properties).
