8.18/6/2018
Create Output
The Create Output Action Task generates Print output in a format specified by a Connect Print Preset and sends this output to the appropriate target location.
The task requires a valid Job Metadata file, normally output from a Create Job or Merge Jobs task.
The job is sent to the OL Connect Server for processing.
Depending on the options set, either a simple metadate file with information about processing is returned, or the actual output file created by the server.
Properties
The Create Output Action Task properties are as follows:
Connect Proxy Tab
This tab is common to all OL Connect tasks and defines where to process the jobs send through these tasks. When these fields are empty, they use the defaults set in the OL Connect User Options page of the preferences. Note that defaults are not used unless the configuration is sent to the Workflow service.
Common Errors
Comments Tab
