8.18/6/2018
Create Job
The Create Job Action Task prepares a series of print content items for output generation. A Job is not actual contents but simply a collection of content items ready to be printed.
The task expects to have a valid Print Content Set, output from the Create Print Content task, or the result of the Retrieve Entities task set to retrieve either Content Items or Content Set.
The task prepares the content items or content sets for printing, tagging them as printable. Only the content items that are part of the job will generate output.
The task outputs a Print Job ready to be sent to the Create Output task for printing.
Properties
The Create Job Action Task properties are as follows:
Connect Proxy Tab
This tab is common to all OL Connect tasks and defines where to process the jobs send through these tasks. When these fields are empty, they use the defaults set in the OL Connect User Options page of the preferences. Note that defaults are not used unless the configuration is sent to the Workflow service.
Common Errors
Comments Tab
