8.18.12015-07-23
HTTP Server Input
HTTP Server input tasks are used to receive HTTP requests made via GET or POST commands and to send replies to the servers from which the requests were made. The HTTP server supports both http and e. For HTTPS Support information, see HTTP Server Input User Options.
While you can insert the HTTP Server Input Task anywhere in your process as a secondary input task, in reality the HTTP Server Input Task will only function when used as the initial input, as it is triggered when PlanetPress Workflow HTTP Server receives a request and passes it on to the correct task.
It is highly recommended to make all processes using the HTTP Server Input task Self-Replicating and to reduce their polling interval in the Process Properties.
The HTTP Server Input task does not, by itself, capture any files. Neither does it directly wait for requests to be received. Actually, it is the HTTP service that receives the requests and places them in a specific location on the drive. When a request is received, the HTTP Server Input polls that location and finds the requests and all attachments. It will always pick up the "oldest" request received.
The request can contain one or more files, one being an XML file containing the request information as well as any GET or POST variables that were received within this request. Other files are POST attachments.
By default, the request XML also contains a CDATA section which contains the raw input data, effectively doubling the size of the incoming file. Due to technical restrictions, the incoming XML file cannot be more than 400MB, which because of CDATA is reduced to around 200MB. To help in this situation, you may elect to omit CDATA from the attachment, which can be changed in HTTP Server Input User Options. Please note that this limitation also affects incoming binary files (sent through file upload in a form), regardless of CDATA settings.
Depending on the options chosen in the HTTP Server Input task properties, the task may choose to ignore some of the files. For example, using the "Do not include XML envelope" means that only the POST attachments will be used in the process, the XML file will be discarded. Attachments are always saved on disk in a specific location, which is accessible either directly in the XML or directly as a data file through the "Loop each attachment as data file" option.
First, the output inside the process itself is, depending on the selected options, an XML request files, POST Attachments files, either one or both.
If the "Send Immediate Response to client" option is selected, the response file is sent back right away and the involvement of the input task ends then. However, if this option is not checked, it means there is a second output that comes out of the HTTP Server Input task: The last output generated by PlanetPwress Watch is sent back to the initial input, which is returned back to the client.
Starting in version 7.2 of PlanetPress Suite, you can now serve static resources through PlanetPress, which is especially useful for images, CSS and Javascript files. See HTTP Server Input 2 User Options.
HTTP Server input task properties are as follows:
"Other" Tab
Examples & Use Cases
Common Errors
Comments Tab
