8.18.12015-07-23
Variable Properties
When you edit tasks, you may notice that some of the properties that you can modify have a red (or more precisely, a maroon) title. This means that the property can be dynamically determined whenever your process runs, that is to say it will not remain static. This can be extremely useful when, for example, you want to determine how many copies you will print out depending on your data, or what document will be used in the printout depending on the department it came from.
Variable properties may include:
Variable properties can also be used in these special locations:
Variable properties can also be mixed, meaning you can combine, within a single variable property box, any number and order of variable types. You can, for example, do the following for an output file name: %O_@(1,1,1,30, KeepCase,Trim)_%y-%m-%d.txt. This would translate in the original filename, followed by part of the first line of a text data file, then the current date.
Contextual Menu
In any variable properties box, you may use the contextual (right-click) menu to add variables and control characters, as well as to get data and make data selections. The lower part of the contextual menu is divided into 4 items that provide variable properties:
Get Metadata Location and Get Metadata Value, introduced in PlanetPress Suite 7.4, can be of great help if working with very large data files that take too long to display in the Data Selector, or files that are of a format not recognized by PlanetPress Workflow. Because the Data Selector does not show the Data tab, it does not load these files so it does not read them or attempt to make data selections on them.
You can quickly identify variable information that is already present in your variable properties as such:
