Reorder Objects in the Configuration Components Pane
There are multiple ways you can reorder objects in the Configuration Components Pane. Commands available from the right-click menu let you reorder selected objects, as well as alphabetically reorder objects listed directly under a category or appearing within a group. You can also use the clipboard controls and drag & drop methods described in
Using the Clipboard and Drag & Drop to copy and move objects and tasks.
To reorder selected objects in the Configuration Components Pane:
- Click an object or group.
- In the PlanetPress Suite Ribbon, go to the View tab then click Order in the Arrange group, then select one of the following:
- Up One Level to move the item one level up in the hierarchy. If the item is already the top object in the category, or within a group, this command has no effect.
- Down One Level to move the item one level down in the hierarchy. If the item is already the bottom object in the category, or within a group, this command has no effect.
- To Top Level to move the item to the top level in the hierarchy. This moves the item to the top of the category or to the top of the group. If the item is already the top object in the category, or within a group, this command has no effect.
- To Bottom Level to move the item to the bottom level in the hierarchy.
To alphabetically reorder objects in the Configuration Components Pane:
- Click the either a category (Processes, Global Variables, Documents, or Printer Queues) or a group
- In the PlanetPress Suite Ribbon, go to the View tab.
- In the Arrange group, select Sort by Name.
