8.18.32016-03-14
Using the Clipboard and Drag & Drop
Moving configuration components in the Configuration Components Pane is very easy and can either be done with the mouse (drag & drop), the Ribbon menus (clipboard buttons) or the keyboard (clipboard keyboard shortcuts).
If you simply wish to change the order in which objects appear in a category or group of the Configuration Components, refer to Reorder Objects in the Configuration Components Pane.
As you drag a configuration component, your mouse cursor will change to indicate the action you are performing, as well as whether the location where the cursor is can accept the configuration component you are dragging. If you try to drag a configuration component in a location that is not accepted, the cursor changes to a "prohibited" icon. If you are moving a configuration component to a valid location, the mouse cursor displays the normal cursor along with a small dotted box. If you are copying a configuration component to a valid location, the mouse cursor displays the normal cursor along with a small dotted box and a plus (+) sign.
PlanetPress Workflow Mouse Cursors
Normal Mouse Pointer
Move Mouse Pointer
Copy Mouse Pointer
Prohibited Mouse Pointer
Moving Configuration Components
Moving components using Drag & Drop:
Moving components using the clipboard buttons:
Moving components using the mouse contextual menu:
Moving components using the keyboard shortcuts:
Copying components.
You can make a copy of any component in the Configuration Components Pane, with the only exception being Documents (of which you can only have one copy). Copying components is done using the same methods as moving them, with the following differences:
Moving and Copying Details:
