Data Matrix settings
A Data Matrix barcode is a high-density, two-dimensional (2D) matrix barcode which supports encoded text, numbers, files and digital data.
Note: In order to create a GS1 compliant Data Matrix barcode, the barcode data must meet the following requirements:
The barcode data must start with a leading FNC1 character. Either ~1 or ~d232.
The GS1 Application Identifiers (AI) must be used for all data.
The function code ~1 must be used as field separator for variable length AI elements.Only ASCII characters should be used.
General group:
Position group:
Data Matrix Properties group:
Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
Encoding: The data represented in the symbol can be compressed using one of the following algorithms:
Auto: Automatically detect the data content and encodes using the most appropriate method. This is the default option.
ASCII: is used to encode data that mainly contains ASCII alphanumeric characters (ASCII 0-127). Use where Barcode size is a concern and where the data is alphanumeric.
Base 256: used to encode 8-bit values.
C40: used for data that mainly consists of numbers and upper-case alphabetic letters.
Text: used for data that mainly consists of numbers and lower-case alphabetic letters.
None: Does not use any encoding.
Format: select the Barcode size format from the drop-down list .
Process Tilde:
Check this option to process tilde characters in the data as special characters.
Note: with this option checked, any tilde that needs to be included in the output must be escaped by adding another tilde: ~~.Note: The following tilde codes are supported in GS1 DataMatrix barcodes:
~1 = FNC1 character (for GS1 DataMatrix barcodes)
~2 = Structure Append
~3 = Reader programming
~5 = Macro5
~6 = Macro6
~7 = ECI expressions
Add button
: Click to display a list of variable data that could be used for generating the Barcode.
Add button
: Click to display a list of metadata fields, information fields to add, or common expressions to the condition.
