KIX Code (Dutch Post) Settings
KIX code barcodes (also known as Klantenindex, or Dutch KIX 4-State), are used by Royal Dutch TPG Post (Netherlands) for Postal code and automatic mail sorting. They contain the address of the receiver, encoded in alphanumeric format (0-9, A-Z).
General group:
Position group:
- KIX Code Properties group:
Track height: The height of the small vertical centre bars, in metric (mm/cm). Value must be between 1 mm and 1.6 mm.
Full bar height: Height of the tallest vertical bars, in metric (mm/cm). Value must be between 4.2 mm and 5.8 mm.
The ascender and descender bar heights are automatically calculated based upon the Full and Track bar heights. -
Module width: Thickness of each bar in the Barcode, in metric (mm/cm). Value must be between 0.4 mm and 0.6 mm.
Module spacing: The spacing between each bar, in metric (mm/cm). Value must be between 0.4 mm and 0.7 mm
- Process Tilde:
Add button
: Click to display a list of variable data that could be used for generating the Barcode.
Add button
: Click to display a list of metadata fields, information fields to add, or common expressions to the condition.
