QR Code Settings
QR Code (Quick Response Code) is a 2D Barcode format that supports alphanumeric, numeric, byte/binary, and Kanji (Japanese-Chinese character) data.
General group:
Position group:
QRCode Properties group:
Size by: Select size from the two options available:
- By area: Connect will try to size the Barcode to fit the specified area by dynamically changing the module width to the Size selection. The lower module width limit is governed by the Minimum module width selection.
Enter the sizes in either metric (cm/mm), inch (in), pixel (px) or point (pt) values. - By module width: Connect will try to size the Barcode to the module width of the characters. Large Barcode values will result in larger Barcode and vice versa.
Enter the Module widthin either metric (cm/mm), inch (in), pixel (px) or point (pt) values. -
Encoding: Define the encoding of the Barcode:
- Auto: Automatically detect the data content and encodes using the most appropriate method. This is the default option.
- Numeric: 7089 numerical characters.
- Alphanumeric: 4296 alphanumerical characters.
- Byte: 2953 characters.
- Kanji: 1817 Japanese/Chinese characters.
Version: Select the preferred QR code version (which sets the data length field) from the 40 available.
The Encoding and Version fields work together to determine how many characters are encoded within a length field. The following table shows the number of bits in a length field, based upon the selections made:
Encoding Ver. 1-9 Ver. 10-23 Ver. 27-40 Numeric 10 12 14 Alphanumeric 9 11 13 Byte 8 16 16 Kanji 8 10 12 -
Error Correction Level: Part of the robustness of QR codes is their ability to sustain “damage” and continue to function even when a part of the QR code image is obscured, defaced or removed. A higher correction level duplicates data within the QR Code to allow for damaged areas. The higher the Error Correction Level, the larger the Barcode will be. The choices are (in order from lowest to highest): Low, Medium, Quartile and High.
Use ECI for encoding messages as bytes: Selecting Extended Channel Interpretations (ECI) allows encoding multiple character sets (e.g. Arabic, Cyrillic, Greek, Hebrew) and other data interpretations, into one QR Code symbol.
Multi-part QR Code (structured append): Select to append a QR Code symbol in a structured format.
Part: indicates the position of the QR Code symbol within the group of Structured Append symbols.
of: indicates how many Structured Append symbols exist.
Use FNC1: Check to enable Application Identifiers. These are often used to encode links to websites, or to encode production/batch details.
Position: Select between the two methods for encoding FNC1 characters within QR Codes:
First Position - uses the GS1 QR Code standard.
Second Position - uses the AIM QR Code standard. If this option is chosen then the appropriate Application Indicator will also need to be set.
Application ID: Enter the appropriate QR-Code Application Indicator in accordance with the specific industry or application specifications (as provided by AIM International).
Note: The Structured Append symbols Part number can never exceed the sum total of Structured Append symbols available (the "of" value). Thus selecting a Part number beyond the existing sum total will increase the sum total to the same value.
- Process Tilde:
Check this option to process tilde characters in the data as special characters.
Note: with this option checked, any tilde that needs to be included in the output must be escaped by adding another tilde: ~~.
Add button
: Click to display a list of variable data that could be used for generating the Barcode.
Add button
: Click to display a list of metadata fields, information fields to add, or common expressions to the condition.
