Royal Mail 2D Mailmark Settings
Royal Mail 2D Mailmark Barcodes are a variant of 2 dimensional Datamatrix barcodes. They are used by the British Royal Mail postal service. They contain the address of the receiver, encoded in alpha-numeric format (0-9, A-Z).
General group:
Position group:
Royal Mail 2D Properties group:
Module Width: The size of each column and row within the barcode. Value must be between 0.5 mm and 0.7 mm.
Preferred Version: Select the preferred size of the barcode in terms of rows by columns.
Note: Depending on the information being embedded, this entry may be overridden if the specified size is not big enough to contain the barcode information.
Tilde processing
Add button
: Click to display a list of variable data that could be used for generating the Barcode.
Add button
: Click to display a list of metadata fields, information fields to add, or common expressions to the condition.
