UPC-A Settings
The Universal Product Code (UPC-A) Barcode is widely used for tracking trade items in stores and at the point-of-sale. It consists of 12 numerical digits which are uniquely assigned to each trade item.
General group:
Position group:
UPC A Properties group:
Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
Checksum: Use the drop-down to select how to deal with the Barcode checksum:
Ignore: Ignore checksum calculations.
Auto: Add a checksum character to the Barcode if the initial value does not validate. This is the default value.
Check: Verify the Barcode has a valid checksum.
Add: Calculate and add a checksum character to Barcode, regardless of current value.
Print human readable text: Check to add a textual version of the Barcode data.
- Process Tilde:
Add button
: Click to display a list of variable data that could be used for generating the Barcode.
Add button
: Click to display a list of metadata fields, information fields to add, or common expressions to the condition.
