US Postal Service IMb Settings
US Postal Service Intelligent Mail Barcodes (IMb) are used by the United States postal service. They contain the address of the receiver, encoded in numeric format (0-9).
General group:
Position group:
USPS IMB Properties group:
Track height: The height of the small vertical centre tracking bars, in inches (in). Value must be between 0.039 and 0.057 inches.
Ascender height: The height of the ascender bar.
This also determines the height of the descender bar and full height bars, in inches (in). Value must be between 0.082 and 0.111 inches. -
Module width: Thickness of each bar in the Barcode, in inches (in). Value must be between 0.015 and 0.025 inches.
Interchar gap size: The gap between the bars, calculated as a ratio of the module width, where a value of 1.0 equates to a gap width the same as the module width.
Value must be between 0.012 and 0.04 inches. -
Print human readable text: Check to add a textual version of the Barcode data.
- Process Tilde:
Add button
: Click to display a list of variable data that could be used for generating the Barcode.
Add button
: Click to display a list of metadata fields, information fields to add, or common expressions to the condition.
