Booklet Options
The Booklet Options page defines how to generate booklets in the output.
It is used in conjunction with Imposition settings, which will appear after the Booklet entries have been made.
This page includes a handy illustration that displays how the final binding would look, based upon the current selections.
Options:
Configuration: Use the drop-down to select the type of binding to use:
- Saddle Binding: This binding places all the pages in a stack, binds the middle and folds the stack as one.
- Perfect Binding: This binding type is often used for books. Pages are folded in the middle and then set side by side. The pages are then bound along the folded "spine".
- 1 up Perfect Binding: This binding does not contain any folding. The pages are lined up side by side and bound along one edge.
Booklet Binding Edge: Use the drop-down to select the side on which to bind the booklet.
Optional Cover
Page selections are available to Saddle Binding only.
Cover Page checkbox: Check to enable cover pages to be created with the options below:
- Media selections:
Cover Media Size: Use the drop-down to select the media size for the cover page, or use a Custom size and select Width and Height values.
- Front Cover selections:
Blank: Select to add no data to the front cover.
First page on outside and second page on inside: Select to use the first 2 pages as the inside and outside of the front cover.
- Back Cover selections:
Blank: Select to add no data to the back cover.
Last two pages on inside and outside: Select to use the final 2 pages as the inside and outside of the back cover.
Advanced Print Wizard and Output Creation Preset Wizard navigation options
Print button (Advanced Print Wizard only) or Finish button (Output Creation Preset Wizard only):
