The Process area
The Process area, which is always available and visible, holds all the tasks, branches, conditions and comments that make up the selected process (see About processes and subprocesses and About Tasks).
The Process area is built like an invisible grid divided by rows (horizontal) and columns (vertical). When adding a new Action task, a new row is added. When adding a Branch or Condition, a new column appears (unless there is already a column at that level).
The first task of any process, also called the initial input task, always appears in the first box in the upper left corner. When you create a new process, this first task is always followed by the default Output task in the following box.
The Process area is where you edit a process by:
- Adding tasks
- Adding a branch or condition
- Cutting, copying and pasting tasks and branches
- Disabling tasks and branches
- Editing a task
- Moving a task or branch using drag-and-drop
- Replacing tasks, conditions or branches
- Removing tasks or branches
In the Process area you can also:
