Create File
Create File input tasks are different from other input tasks in that they do not pull in data from a source location. The data that this task passes along to other task is its own: text or values from variables entered when the task was created or last edited.
Since Create File input tasks are not dependent on data from external sources, they are performed at every polling interval and the process is thus started every time.
Create File does not capture any file and, if it is a secondary input task, discards the current data file.
Create File generates a job file with the contents of its text. If variables and control characters are present, they are evaluated at run-time when the task is executed.
A file created with the Create File plugin will be encoded with the ISO 8859-1 (ISO Latin-1) table.
The output is the job file. No metadata is generated by the task itself, however if metadata is present in the job and it is not deleted (in the "Other" tab), it will remain active.
  • Create File: Enter the text to use as the data. The Create File box is a Variables Properties box, so you can use any of the variables, control characters or data selections as noted in Variable task properties.
  • Add CRLF after last line: Check if you want the plugin to automatically add a new line at the end of the file. Remove the checkmark to leave the file as-is, useful in the creation of CSV files for example.
  • Delete Metadata: Check to delete any metadata attached to your data file.
"Other" Tab
  • Job Information group
  • Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the PReS Workflow Tools working folders under the "Backup" folder.
Job Information definitions
This task does not generate any job information.
